Solved - NEH 4103: 1956 Rochdale Mk6 on Buckler Mk5 chassis
Started by Carnut, June 02, 2015, 07:37:11 AM
Carnut
Easy Rookie point - what's this, from when - for 1 point?:
Carnut
richard cuyler
Am I right in thinking that those are Austin Healey Sprite wheels? If so, is this a glassfibre special based on an AH Sprite?
Carnut
Quote from: richard cuyler on June 16, 2015, 08:11:22 AM
They do look like them but I believe they aren't, no; it might be the hub-caps that help to make them look like a Sprite's, plus of course the holes.
It's a glassfibre special but no AH bits that I'm aware of.
richard cuyler
Is it from Italy, mid fifties?
Carnut
Quote from: richard cuyler on June 17, 2015, 07:54:09 AM
It's from the mid-fifties, but not from Italy...
frederick59
Carnut
AlexFrance
Any connection with Jaguar?
Carnut
Carnut
Bit too easy for the Pro's really but the Experts didn't get it so...  up it goes.
barrett
I'm not sure what you're looking for, but it's a Rochdale MkVI based on Ford chassis and running gear and built in 1956
Carnut
Quote from: barrett on July 14, 2015, 06:32:22 AM
Yes it's a Rochdale Mk6.
I did start out saying it was an easy Rookie point but neither the Rookies (are there any?) nor the Experts wanted it..
However, whilst it does have an 1172 cc Ford sidevalve engine the puzzle car doesn't sit on a Ford chassis.
Locked for you to dig into!  You should be able to go straight to the answer..
barrett
ah, it seems to be a Buckler Mk5 chassis.
Where are the Rookies these days? Does any puzzle get solved at that level any more, even the 'easy' stuff like this?
Carnut
Quote from: barrett on July 14, 2015, 09:21:23 AM
Indeed.
The Rookies board seems to be a bit redundant at the moment!
Another picture:
